S21 ultra one ui 4.0 process system not responding
(Topic created on: 12-03-2021 10:37 AM)
小宇
Seriously one ui 4.0 so unstable. Haven't had this issue before the upgrade. Now keep facing this issue when opening/using apps. Sometimes screen will just freeze and after awhile this error pop up.
9 REPLIES 9
小宇
Here's the screenshot Screenshot_20211203-103053_One UI Home_16652_1638498853.jpg
Brandi804
Beginner Level 4
Did you get this fixed? Bc mine is now doing the same. Smh
小宇
No more system crashed after the new patch. I think it's 2 patches since i posted about the issues. Also try updating play/galaxy apps whenever there's an update available. Maybe the apps were not optimized for Android 12 yet last time. So far no issue now.SmartSelect_20220225-103633_Software update_22881_1645756593.jpg
You may want to try out the method state in this article
https://updato.com/how-to/fix-process-system-isnt-responding-error-android/
djang0U
Tell me about it! My mobile data got murdered by UI 4...
I only once in a long long while encounter something like this no matter which ver of One Ui I m on... Make it a habit to run device care everyday. (Close all apps before this)
1. Press optimise button
2. Clear memory cache
3. Device protection
After all this restart your phone... Some might say no need or I am kiasu but so far because of doing this I have enjoyed an smooth n enjoyable One Ui experience no matter which ver I am on... 👍🏼✌🏼💪🏽
小宇
I just sent an error report log. Yesterday, I used some apps. Suddenly, screen froze and turned black. Then auto restart....
Brandi804
Beginner Level 4
Mine is doing the same since latest update. Mine records me when I'm talking, my volume goes up and down by itself, it's constantly saying I'm offline even though I have unlimited data and my phone constantly freezes each time I'm on a call and then comes up with a message saying "Processing Stopped Working" and then the phone turns black for about 10 min and then restarts itself. I'm beyond pissed with this. This needs to be corrected asap!
mdmcg
same thing happening to me! mic is on, camera flickers. It's now trying to restart but stuck on the carrier logo screen.
