S23 Ultra battery life
(Topic created on: 02-18-2023 12:23 AM)
Zixx
I have been using this phone since 10 feb now and seems like i barely get through a day with the promised new battery optimisation. Can anyone help me out? Why am i experiencing a worser battery life then my previous s21+
On 16feb i had to charge halfway through the day to juice up
I keep AOD, wifi, data and location on at all
times.
19 Comments
JP19
Expert Level 4
I believe battery optimisation will get better over time, as it takes time to learn ur usage.
Zixx
its been a week though and im worried if its my device defact instead
JP19
Expert Level 4
Definitely not. 😆 Batteries tend to be worse at the initial phase of usage. If not, u can try turning on Adaptive Power Saving. It should improve ur battery life. It will turn on power saving mode at a certain % below 68%. It can turn on between 24% and 67%.
Zixx
Hmm okay, I'll continue to monitor the battery. Do you turn on the put apps to sleep/deep sleep mode?
JP19
Expert Level 4
Yes, I have enabled the Adaptive battery, however I don't see the real difference in battery life tho.. 😅
I prefer Adaptive Power Saving, where it activates power saving mode when my phone is heating up a lot, while allowing me to use my phone a bit more towards the rest of the remaining battery discharge.
Zixx
Sorry I was asking about sleeping the apps: Battery > background usage settings > sleep/deep sleep apps.
But yeah i do enable adaptive battery too. Can't really tell a difference.
JP19
Expert Level 4
Oh sorry misunderstood ur question. Yeah I have enabled too, however.. I don't see how it have helped much in the battery life. As these days, battery is pretty much intelligent to know how to draw almost zero power from unused apps.Screenshot_20230218_174216_Device care.jpg
Zixx
Hahaha no worries, thanks for sharing!
JP19
Expert Level 4
No problem 🫡 Hope ur battery will improve over time.
