12-04-2024 08:10 PM in
Galaxy SI seem Samsung 424 Fe has badly Battery Drain Issue .. So Samsung may to note this issue and fix through the update
12-05-2024 03:50 AM in
Galaxy S- Mark as New
12-05-2024 09:49 PM in
12-06-2024 04:38 PM in
Galaxy SHi @SajanKushwaha1,
You might need to track your battery activity in the past few weeks of usage, some apps especially social media (Facebook, Instagram, Tiktok) take a lot of battery as it continues to run and use data in the background.
Similarly, any non-optimised 3rd party apps can also drain your battery - and if you have just updated your phone then it will take a week for it to learn your usage pattern. [Head over here to see some tips on saving battery: https://r1.community.samsung.com/t5/galaxy-s/tips-to-make-the-most-out-of-your-galaxy-phone-s-batter... ]
If all else fails, you should consider getting it checked at your nearby Samsung authorised service centre, which can be found here: https://www.samsung.com/my/support/service-centre/
Hope this helps!
