Sound/Vibrate Mode Feature
(Topic created on: 08-17-2023 08:19 AM)
LeeYan13
Hello. There is a feature that I really want Samsung to add to their smartphones.
This may sound silly but I personally find this very convenient.
This feature is about the Sound/Vibrate Mode feature.
The phone is set to Sound Mode but it turns into Vibrate Mode when the screen is on. I personally don't want notification sounds if I am actively using the phone. I hope there will be a feature that will automatically activate Vibrate Mode when the phone is on, and it turns back to Sound Mode when the screen is turned off.
Thank you for reading my suggestion.
2 Comments
DanielNight00
You could set up a Routine for this, or just simply toggle the Sound/Vibration in your quick settings pannel.
TeamGalaxyBianx
Hey there, LeeYan13! This would be an awesome feature indeed and we'll take note of this! Thanks so much for sharing. For now, just like what Member, DanielNight00, said, you can set up a Bixby Routine for this! To create a custom routine:
  1. Go to Settings > Modes and Routines
  2. Tap the Routines tab, then tap Add
  3. Once you've set up the trigger under "If," tap under "Then" to set up the action
  4. Set up a name for your routine as well as an icon and color, then tap Save
  5. Tap Done
There you go! Let us know how it goes. 😁
