Super charging problem (s21 5g)
(Topic created on: 12-10-2023 08:28 PM)
Josh4480
Beginner Level 3
One time i was using the stock charger for my s21, i noticed that it is not in super charging mode like normally should. Then i tried unplugging and plugging. Then suddenly, a moisture detected notification popped up. I was in a dry environment and i haven't used my phone wet for a long time. Though i still tried dring the charging port, see if the problem goes away but it never did. I cannot use my charger anymore until my battery died out. I tried buying a new charger from the store but it doesn't work in my phone so i have no choice but to return it. Now i can charge using a different samsung charger. It can charge up to fast charging mode but i still would like to know what the problem is and probably use super charging again.
whatsdot
Jwhevs
