Tips for Android MagSafe Battery Pack?
(Topic created on: 04-12-2023 11:49 PM)
Tetaa
Do you have recommendations on which brands have Magsafe Battery Packs for Android? I have an S21+. I was browsing online and most if it are apple compatible only. Do I need a magsafe case as well?
6 REPLIES 6
TeamGalaxyDD
Hey Tetaa,
MagSafe is a proprietary technology developed by Apple for their devices and are not compatible with Galaxy devices. However, there are plenty of brands that sell wireless powerbanks online!
You can also check this out: Buy Samsung Battery Pack 10,000mAh - Best Price | Samsung PH
Tetaa
Do you have recommendations on brands that are similar to MagSafe? Would really like to have a battery pack attached to the phone already
TeamGalaxyDD
I know that MagSafe-compatible cases exist, which allow non-Apple smartphones to use MagSafe accessories.
Here's something I found online: Here's How Android Users Can Live the MagSafe Life Like Me | Digital Trends
Hope it helps!
butete
anker has good reviews
Tetaa
Will check on this too. Thank you :)
mayking
Samsung s8plus
