Mabel-coffeeadd icts
01-07-2024 11:54 PM in
Hello guys. Can I get some recommendations for getting USB c to USB c cable for my phone. Is there any difference in the cable Watt?
Am currently looking at Baseus brand fast charging cable for 2metre in lenght: 100w vs 240W --> any difference ? Any suggestions?
Solved! Go to Solution.
Mad9420
01-08-2024 01:31 AM in
It doesn't matter as long as your cable can support more than 45W (I believe you are using S23Ultra). It will be no difference between the 100W & 240W in this case. I would prefer the 100W because the design looks like it will last longer compared to the 240W
2 Comments
Mad9420
01-09-2024 10:17 AM in
Okay thank you. I bought the 100W cable already.
