why is my edge lighting not working? help please s22 ultra.
(Topic created on: 12-07-2022 07:43 PM)
hardtolove
Help
5 Comments
ProCo
Expert Level 4
Good day! Follow the procedure below.
1. Settings
2. Notification
3. Notification Pop-up Style
4. Select prefered design
5. Done/Ok
hardtolove
I already done it. it work to other notif but for messenger, there's no edge lighting. Do you know how?
hardtolove
i choose the all app option but I only get notif from fb that lights up. The other notif I got is messenger but there's nothing. even notif from here, samsung member. there's none.
TeamGalaxyRene
Sorry to hear that, hardtolove, about your Samsung Galaxy S22 Ultra having issues with Edge lighting not working and we apologize for the inconvenience it caused you.
Before trying the below recommendation, ensure that your Samsung Galaxy S22 Ultra is up-to-date with the latest software updates.
Settings > About Phone > Software Updates > Download and Install > Follow On-screen instructions.
Restart your Samsung Galaxy S22 Ultra > then Switch from "Detailed" pop-up style to "Brief" and Edge lighting will appear.
From Settings, tap Notifications, and then tap Notification pop-up style.
Tap Brief, and then select from the following options:
  • Apps to show as brief: Select which apps you'd like to view as brief pop-up notifications.
  • Edge lighting style: Select your preferred type of Edge lighting with color and effect options. See the next section for more information.
  • Color by keyword: Add important keywords and assign colors to receive personalized notifications.
  • Show even while screen is off: Enable this option to show Edge lighting even when the screen is off.
For more assistance, you may contact us on our online Samsung support channels below.
https://samsung-livechat.sprinklr.com/seao/ph/index.html
Or contact our Samsung direct hotline numbers below.
#GALAXY or #425299 [Mobile Phones & Tablets]
Available 24/7
1-800-10-7267864 [All Product, Toll Free, PLDT]
1-800-8-7267864 [All Product, Toll Free, Globe]
842 221 11 [All Product, Landline]
Daily (8:00am to 8:00pm)
hardtolove
hi it works. but certain apps don't. Like messenger. where in I constantly get a message notifications of.
