Wireless Android Auto (AA) High Battery Drain
(Topic created on: 07-13-2022 01:26 AM)
maxq1
Anyone else experiencing this? Even with my phone screen turned off, batt drain for just a 30 min drive is 15-20% 😡. For context, my s21u is driving (no pun intended 😁) my car's head unit wirelessly. First time using such a setup.
3 Comments
SamsungRightCare
Hi, maxq1,
Really understand what you're experiencing right now. In order to provide you with solutions, here are some basic steps to check your Samsung Galaxy phone's battery health with the Samsung Members app as follows: (Ensure that you are in a safe park area and not driving any vehicle while performing below step-by-step).
Step 1. Open the Samsung Members app on your Galaxy Devices.  (Samsung Members | Apps & Services | SAMSUNG PH)
Step 2. Tap the Get help option from the bottom of the screen and select View Tests.
Step 3. Tap Battery status.
Step 4. Here, you'll see information related to your Galaxy phone battery such as Battery power, Life, Capacity, and, Charging. In the case of battery life or battery health, you'll see the following results:
* Good
* Normal
* Weak
In addition, you may also want to check for any open Apps while using Wireless Android Auto.
Hope this has helped you out!
Drive safe always and have a nice day ahead!
maxq1
Thanks but batt health is good. Whenever I start AA wirelessly/head unit server I'm sure there's no other apps running. I did observe that whatever's running on my car's head unit (HU) is also running on my phone, albeit phone's screen is off. Methinks it's just a type of mirroring (thus the batt drain) and I guess that's just how wireless AA is
SamsungRightCare
Dear maxq1,
You may choose the below items in order to reduce your Samsung Galaxy phone battery consumption:
Your device provides various options that help you conserve battery power.
1. Optimize the device using the Smart manager.
2. When you are not using the device, switch to sleep mode by pressing the Power key.
3. Activate power saving mode.
4. Close unnecessary apps.
5. Deactivate the Bluetooth feature when not in use.
6. Deactivate the Wi-Fi feature when not in use.
7. Deactivate auto-syncing of apps.
8. Decrease the backlight time.
9. Decrease the screen brightness.
Hope this has helped you more!
