Overheating and Battery Drain
(Topic created on: 10-16-2019 02:53 PM)
OBA1968
Questions
Is anyone experiencing overheating and battery drain?
Since installing the beta, I noticed a serious overheating issues. I have to wipe cache and dada twice in less than 24 hours before I could use the phone. This needs to be addressed, as the overheating is causing battery drain as well. I have submitted a report.
In case anyone else is facing this problem, wipe cache and restore to factory setting. I took those steps and the phone is good again.
9 REPLIES 9
daschmee12
Questions
yes, when I plug in to charge, phone overheats and displays error saying phone is too hot
ccmercedes
Questions
I don't, if you're having issues try clearing your recent apps, high memory consumption equals heat
Tel864
Questions
well, it is the 2nd day of the 1st beta, stuff like this will happen.
EvelynGS
Questions
Not overheating but definitely battery drain
Questions
same issue here
badmark
Questions
same
BillyxAllen
Questions
Clear your system cache. Power off the device, the hold the power, bixby and volume up button. Release the buttons once the Samsung/Android splash screen. Use the volume button to scroll down to "clear/delete cache. Use the power button to select. Confirm you want to clear your cache then reboot once cache has been cleared.... if this doesn't work then backup your phone and factory reset the device. When a phone does major update sometimes a factory reset is required. It's a pain in the **bleep**, but it typically solved the problem. make sure you're reporting this too
DepecheMode
Questions
if your phone has heavy apps usage it's best to do a backup then a full factory reset as some apps may be having conflict being that it was on a previous official firmware then jumping straight into a whole new Android version even if it is a beta.
SamsungUSABetaTeam
Questions
If solution provided by @BillyxAllen doesn’t help, please send us an error report with screenshots from One UI Beta App (Beta Feedback -> Send feedback-> Error Reports -> "Select Category" -> Input frequency and Description" -> Send (Top Right Icon). We appreciate your help for supporting beta program.
