Resolved! Solved
Guys i need help how to fix Check charger/usb port
(Topic created on: 09-26-2022 01:39 AM)
DEV_Original
Support
sometimes i can't charge
Resolved!
30 REPLIES 30
DEV_Original
Support
ok
ProCo
Support
Reason that unable to charge the device, it reached 0% of battery. Be mindful about your device battery percentage. Much better if you dont drain you device, when your device has only 20% battery you need to plug it to charged the device, this will give your battery life more longer. Thank you.
DEV_Original
Support
its not about percent its about check charger/usb port moisture has been detected in your charger/usb port
ProCo
Support
I see, is it possible to return your device to the service center for another repair.
Khaled75
Support
Is the USB port clean now?
Edit: If you couldn't find my comment, it's because of Samsung Members server issue.
DEV_Original
Support
Totally im charging😂 i dont know how to clean it
Khaled75
Support
Clean the USB port using a brush or toothpick.
DEV_Original
Support
ok
Khaled75
Support
Khaled75
Support
Did you clean the USB port?
