Problem with Remote Control
(Topic created on: 07-06-2025 12:31 AM)
shane999999
Support
I have a Samsung QE55S90CATXXU
I have had repeatedly problems with the remote control.
It kept saying on screen remote needs charging. The moment I connected it to a USB it said charged and would work. The moment I disconnected it the message on the screen was the remote needs charging and it would not work.
I had the remote replaced and the same thing has happened
Please help this is intensely annoying
1 REPLY 1
Amir_13
Support
Try consult the remote connection samsung inside my profile has that function and you call samsung hotline .
