does anyone elses battery plummet when they connect their smart watch
(Topic created on: 10-18-2019 05:49 PM)
enpedia
Tips
First off the smart watch page on the Galaxy wearable app doesn't work but Galaxy buds Doo and whenever I do connect my watch to my s10 my phone seems to die noticeably faster anyone else?
10 REPLIES 10
Tips
I've also have the same issue since I only use my Galaxy watch whenever I'm not home
Gdgetguru
Tips
No issues here with that
Tips
No issues with my Galaxy Watch. Double check you have the latest version of the Wearables App a d also your watch software. If it isn't an issue with either of those, then I would submit an error report.
Jman23
Tips
no issue with my Gear s3
racedog
Tips
No problem with my Gear S3 and the beta or the wearables app on the phone. Just bought a watch active2 and no problems there either with the wearables app and/or phone.
Tips
bluetooth 5.0 is more efficient
Calder
Tips
Just FYI ...asking about user problems should be in the Questions section.
The Tips section is where a user posts advice about how to do something or fix something
Diamondlife51
Beginner Level 3
Tips
this may be weird but my battery seems better when I have the watch connected and this is before the beta and it still happens. galaxy s10 plus and galaxy watch.
SamsungUSABetaTeam
Tips
Thank you for your feedback. If you have not already raised an error report for this issue, please send us an error report with screenshots from One UI Beta App (Beta Feedback -> Send feedback-> Error Reports -> "Select Category" -> Input frequency and Description" -> Send (Top Right Icon). We appreciate your help for supporting beta program.
