Buds3 Pro Blade Lights
(Topic created on: 01-18-2025 05:14 PM)
Wearables
Hello Members! Hope you're all having the best of weekends. Let me share with you a feature on the Buds3 Pro that people seldom talk about. The futuristic blade lights!
Did you know? Located on the stems of the earbud is a strip of LED called the Blade Lights. Turning it on allows you to flex that this is a completely unique and different buds from *ahem, coughs* the fruit brand 😆.
The Buds3 Pro with the blade lights.
Once paired with your device, go into your Samsung Wearables app following the instructions below.
Steps for you to customize the blade lights so that you can stand out in the crowd.
Once you're inside the control page, select your favorite lighting style! Your buds will remaim LIT as long as it has >30% battery.
My personal favorite style is the blinking one.
How do you activate it once it's set up? Simple! Just remove both buds from the case, and pinch the stems as per the next video!
Activate/deactivate the blade lights with a pinch!
Hope you enjoy this tip and also leave your friend gaping with awe at the light-show! 🤣
3 Comments
penguinz1
Wearables
Buds3 pro looks cool but im sticking with my buds2 pro for a while its still pretty good even tho its a year old
MDAkIzz
Wearables
D
Amir_13
Wearables
Well ,I get that after a few months,I will do review for members something special
