Charging 2 devices with the same charger
(Topic created on: 01-11-2023 07:08 AM)
Reubennn
Wearables
Hello, I just wanted to ask because I can't figure out if it's okay to use the same Samsung charger for 2 devices such as my phone and galaxy buds but their sockets are the same type-c, the charging port of one device might be damaged in the long run. is it required to use the type-c cable that came in the box with my buds?
2 Comments
TeamGalaxyRene
Wearables
Hello Reubennn,
Thanks for sharing your Samsung Galaxy experience while charging with inquiry, here.
Charging isn't the most exciting aspect of a phone, tablet or buds, but it's a vital one. You can charge your device using any Samsung travel adapter, but charging speeds may vary depending on the charger. Using the charger that originally came with your phone or tablet is recommended. If you need additional cables, power adapters, batteries, or replacements, only use Samsung charging devices and batteries.
The correct charger is usually included in the box, but if you are in need of a new one, you can purchase charger replacement directly from Samsung.
https://www.samsung.com/ph/support/service-center/
Samsung does not recommend using any chargers other than Samsung chargers, especially chargers that are uncertified or counterfeit. These can hinder the charging of your device and may cause battery issues if used long term. Always make sure your charger is an authentic Samsung charger.
For more assistance, you may contact us on our online Samsung support channels below.
https://samsung-livechat.sprinklr.com/seao/ph/index.html
Or contact our Samsung direct hotline numbers below.
#GALAXY or #425299 [Mobile Phones & Tablets]
Available 24/7
1-800-10-7267864 [All Product, Toll Free, PLDT]
1-800-8-7267864 [All Product, Toll Free, Globe]
842 221 11 [All Product, Landline]
Daily (8:00am to 8:00pm)
Venzerous
Wearables
There won't be any issue with it as long as you're using an authentic samsung charger. Better keep the cables and use it once the one's you're already using became defective.
