Resolved! Solved
Geat S3 Battery Replacement Pricing
(Topic created on: 12-14-2021 02:05 AM)
MelviinKhoo
Wearables
Any one tried to replace Gear S3 Frontier battery in Samsung's service center? May I know how much it cost in Malaysia?
Wearables
Good morning , bro ! I jus help you to contact the customer service . The estimated price is around rm100-rm150 , the price include labor , however , this is an estimation price . You can bring your watch to the nearest service center and give the technician to check first .
if you feel my solution is helpful for you,  pls click 3 dots on right hand side of my comment >>> "Accept Solution" . Thank you😃
SmartSelect_20211214-082131_Chrome_170172_1639441292.jpgSmartSelect_20211214-081954_Chrome_170171_1639441194.jpg
6 Comments
Wearables
Samsung_9l62xs8
Wearables
May I know where I can get my Samsung S3 watch battery replaced? I stay in puchong, Selangor. Tq very much
Wearables
Hi, u can find the nearest SES for the replacement.
https://www.samsung.com/my/samsung-experience-store/locations/
Have a pleasant day 😃
MelviinKhoo
Wearables
Thank you bro! Appreciate your help!
Wearables
No worry , bro! 😀
MelviinKhoo
Wearables
Hi everyone, some update on the battery replacement specifically in Samsung Penang Egate. The replacement is estimated to be RM260 and you will need to leave your gear for 1 week due to no on-hand stock.
I'll share the exact amount once the repair is done.
Cheers!
