AsylumLung
12-18-2022 08:50 AM in
WearablesHi,
I just did a factory reset on my Galaxy A53. Tried to connect my SmarTags, to my Smart Things app, but it failed.
So I reset my tags. And now, when I try to add them again, it says it's registered under another user. I'm obviously that other user.
It tells me that the user needs to remove the tags from his Smart Things. Those tags are not available in my Smart Things app anymore, or in my Samsung account online.
Any help or suggestions is greatly appreciated. Thank you.
1 REPLY 1
JP19
Expert Level 4
12-18-2022 08:44 PM (Last edited 12-18-2022 08:49 PM ) in
Wearables
https://www.reddit.com/r/SmartThings/comments/wpwcgk/smart_tag_wont_reset_even_after_disconnecting_i...
Hi AsylumLung, have u tried this method?
https://www.samsung.com/us/support/answer/ANS00088244/
Or have u tried the following methods?
Sorry I haven't owned a SmartTag before, so I can only find other sources to help u, hope u don't mind. Thanks.
