A few questions regarding Samsung's Auto Blocker setting
(Topic created on: 04-24-2025 04:15 PM)
FalconAgent13
Discussion
Hey guys!
Does anyone know if enabling/activating the Samsung Auto Blocker setting will drain my phone's battery? If so, any idea how significant the drain would be?
If it is a battery drain, would it be worth it to have this setting enabled?
Whether or not this app drains battery, how effective is this feature in the first place? Would you guys recommend this setting be active?
Just in case this affects your answer - I'm using a Samsung S24 Ultra.
I hope this isn't considered a silly question😅
Thanks so much in advance!!
2 REPLIES 2
Andyaus1
Discussion
No, it won't drain your battery, I have it enabled
FalconAgent13
Discussion
Thanks for letting me know!
