Charging Stopped - Your phone's battery temperature is too low
(Topic created on: 07-27-2022 03:28 AM)
EnanKurt
Beginner Level 3
Hi guys, I really need help regarding this charging problem of mine. My phone's certainly not too cold, I'm sure of that. I live in the Philippines and there's no winter here. I really need your advise to remedy this.
6 Comments
pham_hni
It's the temperature problem. Better take it to Samsung Service Centre to have it checked.
butete
try charging it when the phone is off
pham_hni
It will show the same. It's basically a Temperature sensor problem . Saw this on many other sams.
Kenx
There might be a problem inside it. The best way is take it to nearest Samsung Service Center in your area.
Khaled75
Bring it to a Samsung Service Center to have it checked.
SamsungRightCare
Hello EnanKurt,
We are here to help. Please follow below troubleshooting steps.
1) Restart the device.
2) Close all the applications that are currently running in the background of the phone.
3) Charge the device using another charger.
4) Verify, if the phone has been dropped or has any sign of physical damage.
5) Place the device in Safe Mode.
6) Backup and Factory Data Reset.
7) If problem persist, refer to Samsung Authorized Service Center for further assessment.
https://www.samsung.com/ph/support/service-center/
You may use the below links for Tips on mobile devices and Samsung Members app.
https://www.samsung.com/ph/support/category/mobile-devices/
https://www.samsung.com/ph/apps/samsung-members/
Hope your problem got resolved.
