Does Learning Usage Pattern drain much battery?
(Topic created on: 07-30-2024 03:46 AM)
Members_9d6PICM
Beginner Level 3
Hello. Can someone here please explain what might be the issue, if there was. I am using Galaxy A73 5G.
So, for a past few days my battery seems to drain faster I don't know if the Learning Usage Pattern is involved here, especially when it already learned my usage pattern, and already showing the estimation but still it drains fast. I tried to follow some tips here at the community but nothing seems to be working.
My experience from this week I'm charging my battery to 80% (because of Battery Protection and I use first Maximum and switch to Adaptive option) and my SoT circling around 1-4h (with already draining 4-6% in less than an hour) and for Screen Off Time circling about 15h to 20h ( total of 9-11% drain ) this is because I have a pc setup at home and I often use my phone. On the other hand I also disable background data usage in most of my app, especially from Samsung. Until up to this day, I didn't expect for the battery to back to normal (it's just so random). So, I sleep every 4am and woke up at 10am (that 9-11% drain) until this very day when I woke up, to my surprise it only consume 1%.
So, I'm wondering if the learning usage pattern is involved? Because it's kind of annoying my phone suddenly drains quicker when I'm not changing something from the settings, especially with my Screen off time.
I will appreciate your response.
6 REPLIES 6
danesaints
same, ganyan din sakin. gigising ako 8-10% ang nabawas. disable din backround data usage, halos naka deep sleep lahat ng apps ko lalo na yung mga hindi nagagamit. pati notifications ko naka disable na pero ganon padin, sobrang bilis ma drain. 2 mins, 1% ang nababawas. minsan nga bubuksan ko lang yung screen 1% agad ang nabawas. halos 2 months na tong phone ko pero walang pagbabago, mabilis ma drain talaga
Members_9d6PICM
Beginner Level 3
Sinubukan nyo nrin po ba I-disable ung mga services? Katulad po ng mga Google Services or Location Services, lalo n po sa Samsung Services, possible din po ksi sila na mag function parin po kahit naka off ung phone nyo po since nag rereceive prin po sila ng data kahit naka off ung device po. Pero kung nakalagay parin po sa Device Care nyo is "Learning Usage Pattern..." I think normal po ung mabilis sya ma drain since pinag-araalan po ng cellphone nyo ung routine ng paggamit nyo ng phone (based po sa sinabi dito sa community)
Ung sakin po ksi sinubukan ko ung bagong feature na Battery Protection then pinili ko ung Adaptive na option (pero much better po enable nyo nrin ung Adaptive Battery)  for me po medyo tumagal nmn ung drain nya, parang overnight 2% ang binabawas nya nlng. Pero inaalala ko prin baka bumalik n nmn sa dati. Sana po nakatulong prin po.
Gian_Comia
naayos nyona poba yung inyo?
danesaints
hindi po. hinayaan ko na lang, siguro dalwang beses ako charge sa isang araw 🤣
Gian_Comia
sama,nabasa poba yang samsung nyo?
Terrence1412
Hewwo! So Whenever you use your phone and using a app, its called battery consumption. And whenever you use 1-5 hrs, it actually overheating the battery. So please go to a local samsung repair shop and get that battery replaced.
