Problem with battery
(Topic created on: 08-13-2020 02:35 AM)
Arieya
I'm having trouble with my Samsung A50 battery health...it drains fast when i updated to Android 10...What is the best remedy for this? Even in standby mode the battery decreases.
5 REPLIES 5
ProGamer8
It means the battery will drain because of reduced battery performance. Try turning on Power Mode and select medium power saving. Alternatively, Turn off connectivity features that isn't use.
Arieya
tnx i'll try that...
zProSandr
You can do a factory reset on the phone. This many times outputs better performance results after major upgrading to a newer Android version. Like from Pie to Android 10. This method is unlikely to be done on security patches or minor revision updates, but overall, starting to a fresh OS after every update is worth to consider.
Arieya
tnx i'll try to consider that...
Eian
factory reset
