Resolved! Solved
SAMSUNG A12 WIFI CONNECTION PROBLEM
(Topic created on: 02-08-2022 07:11 AM)
dylankimmm
Hi! My aunt bought this new phone 6 days ago for me. Right now my wifi keeps disconnecting in my phone. Other's phone isn't. How can I get rid of this? Im very stress right now.
2 Solutions
butete
Dont stress yourself, its not the phone, its more of the router.
adbautis
Try restarting your router. Also, its possible that the router has limit set for number of active devices connected.
4 REPLIES 4
butete
adbautis
TeamGalaxyDD
Hey dylankimmm,
Please let us know if you've solved your issue by tapping "Accept As Solution" on an answer that helped you!
bachani89
I have the same issue, its not the router or internet connection it is the device itself and has consistently been a problem since I purchased it over a year ago!
