Setting suggestions is draining battery... how do you fix this
(Topic created on: 04-21-2023 07:08 PM)
Not applicable
There are no setting in advance features to turn it off
4 REPLIES 4
Obviou_sly
Send an error report.
Not applicable
Where?
TeamGalaxyRene
Hello SamLmb,
Thanks for letting us know here about how to turn off the setting suggestions, which are likely draining your battery on your Samsung Galaxy phone.
Before you try out the recommendations below, be sure to check if your device's software and related apps are updated to the latest version. To update your mobile device's software, follow these steps:
Step 1. Go to Settings > Software update.
Step 2. Tap on Download and install.
Step 3. Follow the on-screen instructions.
Step 4. Restart your device.
Optimize the overall usage of your phone.
You can optimize your phone using the Device care feature to reduce battery consumption by closing unused apps and controlling abnormal battery usage. Follow the steps below.
Step 1. Open Settings, and then select Battery and device care.
Step 2. Tap Optimize nowDevice care automatically optimizes your phone.
The quick optimization feature improves device performance through the following actions.
  • Closes apps running in the background.
  • Manages abnormal battery usage.
  • Scans for crashed apps and malware.
Optimize individual apps.
Step 1. Open Settings and then select Apps.
Step 2. Tap More options (the three vertical dots).
Step 3. Select Special access.
Step 4. Select Optimize battery usage.
Step 5. Select the app (Settings Suggestions) you want to optimize. Optimized apps use less battery.
Note: Optimised apps will use less battery, but some background functions will be restricted.
Using the auto optimization feature.
You can set the device to perform auto optimization when your device is not in use. Tap More options > Automation > Auto optimize daily and tap the switch to activate it.
Adjust Background usage limits.
The more unused apps there are running in the background, the more power your battery will use. Background usage limits can be set to reduce battery consumption. Follow the steps below.
Step 1. Open Settings and then select Battery and device care.
Step 2. Tap Battery.
Step 3. Tap Background usage limits.
Step 4. Set the app you want to control.
You can choose from the following settings:
  • Put unused apps to sleep will automatically put apps to sleep if they have not been used for a while.
  • Sleeping apps allows you to choose the apps that won't run in the background. You can view your current sleeping apps as well.
  • Deep sleeping apps will never run in the background and will only work when you open them.
  • Never sleeping apps allows you to choose which apps will not automatically be set to sleeping mode.
I hope the above steps will be able to solve the issues draining your device's battery.
Should you need further assistance and guidance, you may contact us via our online Samsung Customer Care support channels below.
https://samsung-livechat.sprinklr.com/seao/ph/index.html
Or our Samsung Customer Care direct hotline numbers below.
#GALAXY or #425299 [Mobile Phones & Tablets]
Available 24/7
1-800-10-7267864 [All Product, Toll Free, PLDT]
1-800-8-7267864 [All Product, Toll Free, Globe]
842 221 11 [All Product, Landline]
Daily (8:00am to 8:00pm)
Be sure to click "ACCEPT AS SOLUTION" when you find our answers helpful to you.
Stay safe and have a nice day ahead! Thanks for contacting Samsung.
Not applicable
unfortunately there is no such special access > optimize battery battery usage in my phone to do so
