12-20-2020 08:56 PM (Last edited 12-20-2020 08:58 PM ) in
Galaxy Note
Hello Note20 users. I've recently switched from s10+ to Note20 Ultra. I've noticed that the SoftKey edge panel (the one with a lock screen and screen shot button) is no longer available for use. What are your alternatives for having a lock screen soft key? I do not like using the assistant button so that's already out of my list.
- Tags:
- EdgePanel
- Note20Ultra
5 REPLIES 5
Magnaguard
12-20-2020 09:14 PM in
Galaxy Note
I have the same phone. For locking the screen, I use Nova launcher then customized gestures so that double tapping an empty space in the homescreen locks the phone. I heard the upcoming One Ui 3 update will include double tap to lock too so you could wait for that.
As for screenshots, I don't use it too much, but I set it up in notification panel just in case. The upcoming One Ui 3 update will allow you to take a screenshot in the app switcher. Your choice.
12-20-2020 09:21 PM in
Galaxy Note
I'll probably wait for the One UI 3. I believe it's scheduled for January on Note20 Ultra correct?
Magnaguard
12-20-2020 09:48 PM in
Galaxy Note
Yes.Although, Ultras in the USA are already getting it this month ahead of schedule, so who knows. Fingers crossed!
12-23-2020 05:06 AM in
Galaxy Note
Out of curiosity I manually scanned software updates. I was able to download One UI 3!
Robbb
12-21-2020 07:50 PM in
Galaxy Note
download samsung's one hand operation app.
