Resolved! Solved
Incoming calls not received and forwarded to someone else
(Topic created on: 05-20-2020 03:15 AM)
Hanna10
Galaxy Note
I can't receive incoming calls and according to those people who called me someone else answered. Someone I don't know. I tried to fix the call forwarding setting under phone settings but it says failed to read data, check your sim card or network connection. How would I be able to fix this?
Charlon
Galaxy Note
try to reinsertsim card. if it didn't work. the next thin to do is to call your network provider and have it deactivated by them.
2 REPLIES 2
Charlon
Galaxy Note
Hanna10
Galaxy Note
thank you. i'll try it.
