Maybe this is solution for flickering screen problem!
(Topic created on: 09-01-2023 01:23 PM)
GalaxyNoteFit
Galaxy Note
17 REPLIES 17
Mchhh
Galaxy Note
curved or not curved, all OLED flicker. you just cant see it with just your eyes unless you're a geeky nerdy one. if you dont want flickering screen, u can opt for IPS LCD display screens.
GalaxyNoteFit
Galaxy Note
TFT LCD can long term use.😂😂😂
Mchhh
Galaxy Note
If you're willing to sacrifice display quality then sure
GalaxyNoteFit
Galaxy Note
IPS and TFT no more use.We no choice because many brand use OLED .
Mchhh
Galaxy Note
I literally do not understand what's your point to comment. What exactly are you trying to explain?
Mchhh
Galaxy Note
IPS and TFT panels are used in cheaper and affordable devices, OLEDs are usually for more expensive ones, or some time midrangers. If you say that we don't have choice to use inferior displays in more expensive devices, you might as well purchase cheap devices in which you can put your trust for long period of use instead of fearing for burn-in or flicker. After all, all display will fail after some time, usually not shortly.
Again, I don't understand what's your point. If you don't know what you're talking about, pls don't project misinformation.
SamNoteUser
Galaxy Note
There are two types of OLED displays: hard (unbendable) and soft (bendable). The hard display connects using a ribbon cable that can be bent into a U-shape to connect to the board. The soft display doesn't require this ribbon cable; it combines all connections into a single connection. This is why some model have problem and others without. This is why some models often have problems, while others do not.
GalaxyNoteFit
Galaxy Note
Curve AMOLED Dynamic 2x is many problem than flat screen.
