Battery drains
(Topic created on: 05-26-2025 12:11 PM)
Lifestyles
Beginner Level 3
S24 after the latest update my battery is draining fast and does not last half a day
Very frustrating 😡😡😡
5 Comments
sahilkamboi
Have you got the latest update issue resolved....
playgirl
I agree ,mine dose the same, & every now & then it will do a little flicker 🤬
Lifestyles
Beginner Level 3
Same here little flicker
jwr71
My three bottom toggle button are slow responding to commands and I need to either tap repeatedly (dozens of taps on all 3 buttons) to toggle between screens and apps, or sometimes turn off the phone altogether to restart.
Only happening since the update and only those 3 buttons.
Rest of the screen has no responsiveness issues.
s_amsungjae
Hi Lifestyles,
The device will require some time to optimise to the update, give it a bit and if the issue still persists, submit an error report via the app. Our technical team will take a look into it for you and do their best to resolve it.
Thanks,
s_amsungjae
