Charging Edge Light Effect
(Topic created on: 12-29-2024 02:23 AM)
imedabong
Hi Galaxy S24 Ultra users out there, here's another feature that lets your phone the way it is connected to charger. The Edge Light effect feature. It is OFF by default, so let's give a try.
I provide step-by-step screenshots so you can follow:
1. First, go to Settings and scroll down to Modes and Routines
2. Next, if the Modes and Routines open for the first time, it will ask you to create app in the app drawer as a shortcut. Let's see that you've already open the Modes and Routines and click Routines followed by "+" icon above.
3. In the Create routine page, select first the If to open the menu.
4. Scroll down to find and select the Charging status
5. By default, all are toggled checked so keep it all and select Done.
6. Then the If already selected for its function, go to Then to open the menu.
7. Scroll to find and select the Edge lighting effect once.
8. You can now customize the light effect that you want by selecting the different Effect, its Color, and its delay in Advanced.
9. After that, select Save.
10. You can also rename, select desired logo and color of this Routine. To finish click Done.
There you go, hope this 💡 Tips will give your phone with an exciting way to perform uniquely for you.
0 REPLIES 0
