How to improve S22 Ultra Battery Health?
(Topic created on: 04-18-2023 02:50 PM)
KyleKyle
Hi! I wanna ask how to improve the S22 Ultra's battery health? Lately I've noticed that my battery is draining a bit faster than normal
2 Comments
butete
deep sleep and set some apps retricted on battery
TeamGalaxyRene
Hello KyleKyle,
You are in right spot to ask here about how to improve the battery health of your well-loved Samsung Galaxy S22 Ultra.
In addition to butete's reply, you may consider following the below optimization tips.
Battery life can be affected by various factors, such as device settings, environment, and usage patterns. Understanding these factors and using the settings will help you use the battery more efficiently and for a longer period of time.
Factors affecting Battery Life.
Environment
Battery consumption increases in areas with weak or overlapping signals or with increased screen brightness under strong sunlight or any other light source.
Usage Pattern
Increased screen brightness, longer intervals before screen timeout, high-performance apps, streaming high-resolution content, and location services or other allowed services will also increase battery consumption.
Settings Tips to Extend Battery Life.
How to Optimize your battery life in the 'Settings'
Check the apps with high battery usage.
1) Go to ‘Battery and device care' in ‘Settings’.
2) Tap ‘Optimize now’ to check apps with high background battery usage.
Keep rarely used apps in sleep or deep sleep.
1) Go to ‘Background usage limits' in Battery.
2) Select 'Sleeping apps' or 'Deep sleeping apps'.
3) Tap '+' and select apps you want in sleep status, then tap 'Add' once again.
Enable 'Power saving' mode
When the battery is running low, enable ‘Power saving’ to extend battery life.
Once ‘Power saving’ is enabled, background apps will be restricted from Wi-Fi and mobile data,
and heavy battery-consuming features such as Always On Display will be disabled to extend battery life.
You can select and adjust CPU speed, brightness level, and Always On Display to your preference.
Change Display Settings
Turn display off by pressing the power button when the device is not in use.
Set ‘Screen timeout’ to a short interval. Lower your brightness. The brighter the screen, the higher the contrast ratio, which leads to higher battery consumption. Extend battery life by using a dark-tone wallpaper or theme.
https://www.samsung.com/ph/support/galaxy-battery/optimization/
Other tips to improve battery life.
1) Disable Always on Display.
2) Turn Off Location Services
3) Update your phone.
Should you need further assistance and guidance, you may contact us via our online Samsung Customer Care support channels below.
https://samsung-livechat.sprinklr.com/seao/ph/index.html
Or our Samsung Customer Care direct hotline numbers below.
#GALAXY or #425299 [Mobile Phones & Tablets]
Available 24/7
1-800-10-7267864 [All Product, Toll Free, PLDT]
1-800-8-7267864 [All Product, Toll Free, Globe]
842 221 11 [All Product, Landline]
Daily (8:00am to 8:00pm)
Be sure to click "ACCEPT AS SOLUTION" when you find our answers helpful to you.
Stay safe and have a nice day ahead! Thanks for contacting Samsung.
