Issues with Removing Circle containing 4 squares AND Changing the Call Answer Buttons to Press Only
(Topic created on: 06-23-2022 11:51 AM)
Blacky17557
Hi.
I have 2 issues with my Samsung S22 Ultra that I hope someone can help with please.
To remove a Floating Circle containing 4 squares, I was told to go to Settings - Accessibility - Interaction and Dexterity - Assistant Menu. Turn off the Assistant Menu and the Circle containing 4 squares disappears.
I also wanted to change the Answer Calls Buttons to Press Only and not Slide.
I was told to go to Settings - Accessibility - Interaction and Dexterity - Assistant Menu - Replace swipe with single tap and turn that to ON.
As this is part of the Assistant Menu it seems that I can't have both.
Hoping that there maybe a workaround and/or solution please.
2 REPLIES 2
SamsungLaura
Hi @Blacky17557, thanks for reaching out.
I suggest going into:
Settings > Accessibility > Interaction and Dexterity > Assistant Menu > Toggle Transparency to high + > Toggle on 'Show as edge icon'
Blacky17557
Hi and Thank You so much for providing this information for me.
It seems to have resolved both the issues that I mentioned.
I really appreciate your help .....
