One Ui 6 on S22 problems
(Topic created on: 01-22-2024 04:34 PM)
r11v03
Welp, the animations are trash. Stutters and lags. Using swipe gestures is also awful. Have always been a swipe gesture user and i have to say, the animations and fluidity on this update is trash.
15 REPLIES 15
r11v03
hope they'll fix it with the next update
JP19
One UI 6.1 update will be the most anticipated update ever.. especially the AI features and also the animation effect will be greatly improved (not sure if it applies to all models).
r11v03
i dont think the s22 will receive the ai features though, im just eagerly waiting for the animation to more fluid
JP19
Yes.. I heard so too.. for AI features, only 2023 flagship models will get it. Not even mid range.
Other than AI features, the non-AI features like better animation effect, new battery protection capabilities will come to those alr eligible for One UI 6.0 update.
r11v03
Hey i found a small fix to the animation, just go to your homescreen settings, scroll all the way down till you see about homescreen, then click update. I just had mine updated. The animations for opening and closing the app slightly improved but the animation for the task changer still *** imo.
JP19
Hey r11, I just checked my Home screen latest version. Is it the same as yours? It shows latest version.1707051484343_1707051484332_0.jpg
