overheating issue
(Topic created on: 03-13-2022 08:41 PM)
hudaaaaa
does everyone had overheating issue on their s22ultra? i tried restart the issue wont solve. or should i just wait for another software update from samsung? does anyone know when it is
9 REPLIES 9
scinex
Which apps are you using that contributes to overheating?
hudaaaaa
i guess everytime i used it around 20min above. my previous s20 fe didnt have this issue.
scinex
Do you notice processor is throttling down causing apps less responsive or you feel it's a bit warm in general?
hudaaaaa
not really. and im pretty sure its not just a bit warm.
scinex
Ok. Maybe it's a good idea to install an app that could display processor temperature, so you could at least compare with your S20.
mãęýļ
Rasa panas bahagian atas sebelah kiri?saya ada issue macam tu..
hudaaaaa
sama. scroll sosial media lama sikit pun kadang panas sgt. tu pelik tu
Are you using 120Hz refresh rate? High refresh rate also could contribute to overheating.
In general, a new device, regardless of any brand, will tend to have few common issues like this until software updates are followed time by time to resolve the problem.
Demoron
Sometimes phone case can contribute to heating as well. I'm using spigen cryo armor case.. super in heat dissipation. You can give it a try.
