Pause USB Power not working
(Topic created on: 04-13-2023 02:39 AM)
JojoL
While playing a game, I have activated the "Pause USB Power Delivery" but to my disappointment, the battery was still charging -- it was at about 65% when I activated the pause power delivery option.
Am I missing something?
1 REPLY 1
TeamGalaxyRene
Hello JojoL,
We are sorry to hear about your disappointment with your Samsung Galaxy S23 Ultra having issues with Pause USB Power Delivery, while the battery was still charging and at about 65% upon activation.
I feel it and understand it. But don't fret; we are here to guide, assist, and offer solutions to restore your device to optimum performance.
Before you try out the recommendations below, be sure to check if your device's software and related apps are updated to the latest version. To update your mobile device's software, follow these steps:
Step 1. Go to Settings > Software update.
Step 2. Tap on Download and install.
Step 3. Follow the on-screen instructions.
Step 4. Restart your device.
With ‘Pause USB Power Delivery’ feature is a direct power supply method to the system bypassing the battery. When the feature is enabled in a PD charger (PPS* supported TA, 25W↑) connected status on the phone during the game, power is supplied to the system through a charger, and physical battery charging is minimized. It improves the phenomenon of performance degradation/throttling by device heat, and the possibility of lifespan deterioration caused by maintaining of continuous battery charging in the high-temperature situation.
It can be turned on/off directly through the user option in Game Booster settings.
  • * Path: Game Launcher app > More > Game Booster > turn on ‘Pause USB Power Delivery’
Operation Condition
  •  When a PD charger(PPS* supported TA, 25W↑) is connected to the device, the option is exposed continuously during the game once it is implemented after installation, then you enable that feature on the menu.
    Pause USB Power Delivery mode is a function that operates only during the game, and is disabled and switched to battery charging state when the device operates other task than the game such as Display off (game not terminated)/screen switched to another one), connected with normal TA or not charging.
  • The mode is enabled only when Battery SOC (State of Charge) ≥ 20 %
    [Supported models] - (Since S22 series) S23/S22/TAB S8 series, Flip4/Fold4 , A33, A53, A73, M33, A23.
    * PPS (Programmable Power Supply): PPS is an advanced fast charging technology standard for USB-C devices that can adjust the voltage and current by feeding with maximum power depending on a device’s charging status in real time.
  • PPS supported TA = PD3.0↑ TA (PD: Power Delivery)
  • Path: Game Launcher app > More > Game Booster > turn on ‘Pause USB Power Delivery’
    • Required PD charger(PPS* supported TA, 25W↑) connection and Battery SOC(State of Charge) ≥ 20 %
If that doesn't fix the problem, you may submit an error report through the Samsung Members app as follows:
Step 1. Long press Samsung Members icon on Apps screen and tap Error reports.
Step 2. Tap OK on agreement popup to send system log data.
Step 3. Select Symptom category "Settings/System" and "Power/Battery/Charging".
Step 4. Describe the problem in details and SEND.
How to submit an error report on Samsung Members app? | Samsung PH
For more assistance and guidance, you may contact us via our online Samsung Customer Care support channels below.
https://samsung-livechat.sprinklr.com/seao/ph/index.html
Or our Samsung Customer Care direct hotline numbers below.
#GALAXY or #425299 [Mobile Phones & Tablets]
Available 24/7
1-800-10-7267864 [All Product, Toll Free, PLDT]
1-800-8-7267864 [All Product, Toll Free, Globe]
842 221 11 [All Product, Landline]
Daily (8:00am to 8:00pm)
Stay safe and have a nice day ahead! Thanks for contacting Samsung.
