Routines don't work when setting times for sleep mode to turn on
(Topic created on: 01-20-2023 10:23 AM)
tomtho
No matter what I do to get Do not disturb working I get this error sign that doesn't let it turn off automatically all the time and sometimes doesn't even turn on. I'm trying to use the sleep mode but it never wants to work. It's so much worse than the old way to automate do not disturb.
6 REPLIES 6
tomtho
It looks like this no matter what I doScreenshot_20230120_091015_Modes and Routines_1000002707_1674170363.jpg
Not sure why it says "the next day$. Can you delete the whole thing and try setting up sleep again?
Can you click on that (turn on automatically) and post a screenshot
tomtho
I've tried a few times but I just get the same issue. This is what the other screen looks like Screenshot_20230120_103904_Modes and Routines.jpg
Could you click on the time? "The next day" is probably the issue, as it never becomes the next day and that means your sleep mode is not being activated
tomtho
I think it should be though? The time selector seems very normal. Screenshot_20230120_111149_Clock.jpg
Can you go to settings->apps then find modes and routines (may have to click on "show system apps"). Then clear data.
Re do your whole modes/routines and see if that fixes it.
