S22 ultra background noise on calls
(Topic created on: 12-07-2022 02:29 PM)
Dibz84
Was wondering if anyone knew how to turn noise cancelling on a normal call without using headphones.
When i am on just a normal call (handheld) the person on the other end complains that the background noise is really loud. Like it picks up birds in the background really loudly. I am not sure if this is a microphone issue or something i need to change. I have googled but cant find any settings or options.
Thanks
9 Comments
I have the S22 Ultra too so have played around with sound settings. Have you tried out 'Adapt Sound', which is in Settings-->Sound quality and effects--Adapt Sounds. If not, give it shot hopefully you'll find a setting that's better for you.
Dibz84
Would this not be for my hearing though? I am wanting to sort the microphone so the person on the other end doesnt hear like birds loudly. The microphone seems to pick up the background noises really noisily i want to cut that out
Liondreamz
I have the exact same problem did you manage to fix it ?
Dibz84
No not at all. And have found no answers either
SamsungClaudette
Hey @Dibz84
Thanks for reaching out. I suggest sending an error report within 2-3 minutes of the issue occurring for this to be investigated by our research and development team. Error reports assist with identifying any deviations in your device performance. Once analysed, our team will get back to you with a response to advise further steps.
To send an error report for a wearable, follow these steps:
  1. Go to Galaxy Wearables app > click on the device desired on the side menu
  2. In the side menu, tap Contact us > Error reports (in the Get help section)
  3. Fill in details and the frequency of the issue that you have with the wearable.
  4. Click send.
Kind Regards,
SamsungClaudette
SamsungClaudette
Hey @Liondreamz
To send an error report:
Samsung Members app > Support > Error reports > select issue category > Describe issue and frequency > Tick ‘Send system log data’ > ‘Send’ in top right.
 Kind Regards,
SamsungClaudette
Dibz84
It is not a wearable. It is the actual phone
SamsungClaudette
Hey @Dibz84
I apologies I sent you the wrong instructions.
I have corrected my message.
Could you please follow those steps and send in an error report.
Kind Regards,
SamsungClaudette
Pooritoo
Beginner Level 3
In WhatsApp calls, there used to be an icon through which you could choose whether you wanted noise cancellation on, standard, etc.
After the UI update, I was hoping that my problem would be solved, but there is still no such option for either WhatsApp calls or Google Meet calls.
The people on the other end still hear a lot of loud noises, especially when I'm using my Buds Pro 2.
