S22 ultra sudden screen display issue
(Topic created on: 09-22-2023 09:15 AM)
jmichael123
On my s22 ultra, a sudden white line showed up while i was checking my messages. I turned it off and back on.. but the still no changes. I checked youtube and found a lot of videos from other samsung users with same exact screen iaaues.. i have never dropped my phone and doesnt have any dents or scratches as i took good care of it. THIS IS NOT A CHEAP PHONE... I HAVE OTHER PHONES THAT ARE MORE THAN 5 YEARS OLD AND STILL ARE WORKING AND NO ISSUES AT ALL.. THIS S22 ULTRA OF MINE IS ONLY 1 YEAR AND 1 MONTH. AND I TOOK EXTRA CARE OF IT SINCE ITS VERY EXPENSIVE. WHAT SHOULD I DO? AND THIS IS NOT A HARDWARE ISSUE .. THE SCREEN ISSUES DISAPPEARS WHEN I CHANGE THE SETTINGS 60 REFRESH RATE.. BUT WHEN INUSE 120 THE BACKLIGHT ISSUE COMES BACK.
12 Comments
Seiichii
Is it straight line at the center of the screen?
jmichael123
Nope.. top right corner of the screen horizontal white line... it disappears when changing the refresh rate down to 60.. comes back if 120..
rynzentre
Nobodyknows
Beginner Level 4
Same with me, so frustating.
J3kton
Dami na complaints about display issues (green lines, discoloration, etc.) Nakakafrustrate lang kasi walang ginagawa ang Samsung about it. I'm using s23 ultra now, it has no issues as of the moment pero nakakaparanoid din kasi lalo nga na di biro ang price ng units natin.
vjygoel
Same issue with my s22 ultra. Developed the white line on the top right side of screen.
jeetec
Same issue here po. Samsung is not doing anything about this. The service center gave me a quotation of more than Php 14,000. This could increase pa po daw depending on the repair pa +++.
mackymacks24
happened to me too.days after a security patch update.phone never been dropped.it flickers when set on 60hz when you double tap from standby mode or when you open your phone from lock screen mode. it is worse when set to 120hz because the line is visible and the screen is like set to 100% brightness
Roiedizon25
Same with mine, but ive seen posts that samsung did not charge for the screen replacement even with lapsed warranty.
