S24 FE wireless charging
(Topic created on: 12-06-2024 10:38 PM)
Omme79
Hi, anyone having issues with S24 FE wireless charging? I'm using Aukey portable charger. My S22+ no issue. But S24 FE seems can't charge.
5 Comments
JP19
Expert Level 4
Hi, can u try this method: use ur S22+ to reverse wireless charge ur S24 FE? See if ur S24 FE charges.
Omme79
Hi, thanks for the info. Yes, it can be charged. Probably I'm using a magnetic case which is not compatible for the wireless charging. I've removed it, and the wireless charging is ok.
JP19
Expert Level 4
Ah I see.. the magnetic case interferes with the wireless charging coil in ur phone. Looks like u can get another non-magnetic case for permanent solution 😉
Omme79
I'm using magnetic case for my magnetic wallet 😂 will get use to it🙏
JP19
Expert Level 4
Hmm.. one way is to still keep ur magnetic case, when u need to wireless charge ur S24 FE, then remove the casing. Normal wired charging, u can still keep ur case on.
