S24 Shaking Sound
(Topic created on: 04-22-2024 09:04 PM)
MsIra
Hello,
Anyone here using S24? I can hear a little sound when I'm shaking vertically. There are no visible cracks and diagnostics are all good. I have'nt droped my phone but there are instances that my bag will accidentally fall from the chair and my phone was inside.
4 Comments
TeamGalaxyDD
Hi Mslra,
You might be hearing your camera array - particularly, the optical image stabilizer, which suspends the lenses in a way that lets it stay stable even with movement. 😄
Check out this video:
[video]
MsIra
Hello, I can't seem to play the video, when I open it, it's only a picture. Is the sound I am hearing from my device normal.
Yep, it's the camera lens. The bigger the lens the more likely it would move when you shake it especially if the device cameras have OIS. It will only happen when the device is not using the camera, coz the OIS (optical image stabilization) mechanism ain't being powered.
You can test it out by using the camera and gently shaking the device, you won't hear the tapping sound or knocking sound. However, I do suggest not doing it intentionally and doing it frequently coz that can damage the camera lens.
MsIra
Thank you so much
