S25 ultra heating problem
(Topic created on: 02-09-2025 08:30 AM)
ArunM
Beginner Level 3
I am using S25 ultra for a week and it is literally overheating on normal usage. I am not using any games or large memory usage apps.
Moreover, I have s23FE for a year and does not get any heating over the period.
Does anyone facing the same issue like me??????
3 REPLIES 3
Try to use power saving mode. And wait for new firmware update. It just came out so it might to have some issues. Hope to fix the problem soon.
Dreamvalentin
That's odd, my S25U runs way cooler than my old S24U. Maybe you should email Samsung support; it might be a faulty unit.
Phoenix0918
Same here, my S25u runs cooler than S24u. 😊 maybe send it back to samsung care
