S25u battery issues
(Topic created on: 06-20-2025 09:52 AM)
Chris022022
Hello everyone,
Battling my issue with battery on s25u. Nothing has seemed to improve it. I wanted to download good gaudians but seems its unavailable in Aust. I am getting at Max 4 hrs SO time and that's charging in between.
Can glass screen protectors effect battery life? Im at a loss trying to figure out how to fix and improve my battery life.some people get 10 hr SOT or longer. Any ideas?
Thanks
3 Comments
alejcho
GG can be sideloaded from sites like APKMirror (or can use things like GSam Battery Monitor)
Screen protectors however don't cause battery drain - maybe can lead to the phone heating up more, but that amount will be too small to have any noticable impact
For fixes, you can try any of the below:
- Drop refresh rate to 60Hz
- Set screen resolution to FHD+
- Lower brightness / use Adaptive
- Turn off Always On Display
- Disable RAM Plus
- Kill apps running in the background (Settings > Apps > Battery > Restricted)
- Check what's sucking power: Settings > Battery > Usage
- Use Power Saving Mode and tick all the boxes
- Turn off Nearby Share, Bluetooth, Location when not needed
- Update software if there’s a new patch
eastlake
Poor signal
eastlake
Poor signal
