Samsung S23 Ultra Battery Saving Tips
(Topic created on: 04-03-2023 07:18 AM)
ArvylleIan
Hey guys, I just got my new S23 Ultra and its been about a month since I bought it. My question is, how do you guys get more than a day's worth of battery life? Any tips, tricks, suggestions? Thank you for those who will answer.
7 Comments
Kong143
Try turning off 5G and use LTE instead and adaptive brightness
ArvylleIan
Turn off or on the adaptive brightness?
Kong143
Off
+1 on this
Khaled75
Turn on the adaptive brightness.
TeamGalaxyRene
Hello Arvyllelan,
Thanks for reaching out to us here in order to have some battery-saving tips and ideas while using your Samsung Galaxy S23 Ultra.
Battery life can be affected by various factors, such as device settings, environment, and usage patterns. Understanding these factors and using the settings will help you use the battery more efficiently and for a longer period of time.
Factors Affecting Battery Life.
Environment -
Battery consumption increases in areas with weak or overlapping signals or with increased screen brightness under strong sunlight or any other light source.
※ Galaxy offers Adaptive Brightness to optimize screen visibility based on the light intensity of the environment.
Usage Pattern -
Increased screen brightness, longer intervals before screen timeout, high-performance apps, streaming high-resolution content, and location services or other allowed services will also increase battery consumption.
How to Optimize Your Battery Life in the 'Settings'
Check the apps with high battery usage.
1) Go to ‘Battery and device care' in ‘Settings’.
2) Tap ‘Optimize now’ to check apps with high background battery usage.
To learn more Samsung Galaxy Battery Optimization tips, you may click the link below.
https://www.samsung.com/ph/support/galaxy-battery/optimization/
For more assistance and guidance, you may contact us via our online Samsung Customer Care support channels below.
https://samsung-livechat.sprinklr.com/seao/ph/index.html
Or our Samsung Customer Care direct hotline numbers below.
#GALAXY or #425299 [Mobile Phones & Tablets]
Available 24/7
1-800-10-7267864 [All Product, Toll Free, PLDT]
1-800-8-7267864 [All Product, Toll Free, Globe]
842 221 11 [All Product, Landline]
Daily (8:00am to 8:00pm)
Let us know if you've found a solution by tapping "Accept as Solution" on the answer you like!
Stay safe and have a nice day ahead! Thanks for contacting Samsung.
rbn101
