TOP RIGHT OF DISPLAY HAS A STRIP OF BRIGHT LIGHT ACROSS TO CAMERA VIEWER.
(Topic created on: 02-06-2024 05:18 PM)
Members_qInqmhQ
Hi Everyone,
My  S22 Ultrahas a strip of bright light (like backlit bright screen) from the right to the camera hole and covering that part of the menu block.  I have found that if I turn off power saving the light comes on.  If power saving is on the light is not there.  ??? And it comes on when it feels like it.
It is not Edge Lighting or Display damage. Can't see anything in camera settings. Not dropped. No water. Have rebooted and reset. Light still appears in Safe Mode.
Bard says there are reports of specific software bugs causing light anomalies on the S22 Ultra -  Software is up to date but ??     I cannot find any downloads for bugs.  Samsung support no know.   SS908E_lockedscreen.jpg
Any tips Greatly Appreciated -  Cheers Cheryl
10 REPLIES 10
SengHourt
I think it is the display issue not the software. You can go to any Samsung Service center to check it
I would agree. If the strip of light doesn't appear during when power saving mode is on, it would be a software bug.
Members_pcPw6gA
I am facing the same issue. Any solution?
Theone1234
 change to standard when power saving is off.
Lnehaa
Omg it worked!!!! Does it mean my mob is okay now or does it still need repairing?????
prajaktm
This seems to be wide spread issue. Most have started getting it after recent software update. One workaround you can try is changing the display refresh from 120 to standard. The band should go away.
Members_JFjyFew
 i do have same problem with my samsung s22
BigSungshow
Just switch on your power saving mode.
makabir33
I am facing the same problem with Ultra S22. Right side of the camera is lighting
