Fold 3 battery Drain
(Topic created on: 03-20-2024 06:11 PM)
CliffAUS
Galaxy Z
Hi is anyone having issues with battery drain during standby for Fold 3. This issues occurred 2 weeks ago. I assume it's due to the Feb 2024 security patch. Overnight it loses close to 25%.
9 Comments
HacktillDeath
Galaxy Z
Well, I was late to update. I've just done it a few days ago, but I've noticed it getting hot, that's for sure, (but I think that could be my other big problem) but yea, today it was the first day I used it as normal and by 12-1pm I need a charge immediately. I've had this z3 since I new, I still rate this z3 as the best S-galaxy I've had since S2 way back. Being a builder bricklayer, I would always crack my screen around the year mark, give or take. But this has made the distance, with a minor faulty screen replacement. But I'm going to document, the power drain and keep you posted
CliffAUS
Galaxy Z
Samsung help team gave me normal advice only like turn off location. I keep my phone to only a limited amount of apps and also keep location on only when using the app. They said charge from 15 to 100 and let it discharge below 15. Send a log file afterwards if problem still occurs. I'll be doing that.
HacktillDeath
Galaxy Z
Sorry, I just saw fold3 😬
Froglette
Galaxy Z
I've, throughout the years, noticed rapid battery drain related to a damaged charging port. If you've ever forgotten to unplug the charger and walked off ripping the cord out, it may have damaged the charging socket connections and battery connection. I have done this to a few phones. But if you cordless recharge, then disregard this comment.
CliffAUS
Galaxy Z
Nah charging port is fine. I quite good in phone structure maintenance. I haven't dropped this phone at all or plug the charging port aggressively. I am 80% sure it's due to the software update.
Froglette
Galaxy Z
👍🏼 thought I'd mention it. I've done it a few times, not knowing as the phones seemed to charge ok, but weren't. So I'm glad that's not your problem.
Galaxy Z
Hi, YES, I definitely see a battery drain since the latest update. I am searching the net to figure out how can I see what cause the drain. The built-in thing just shows which app uses the most battery which is funny enough last time was the always on display, so I guess either nothing does an extra hit on the battery on the app level, or it is indeed the AOD, but I don't think so...  I wish there were an app shows on system level to see what actual process or whatever drains the battery, does anybody know anything like that? BTW I already performed a cache partition cleaning some say it does something some says it doesn't in my case no change...
Annoying, I am thinking of buying a new phone.
CliffAUS
Galaxy Z
I think Accubattery is your best option to see discharge.
R-one
Galaxy Z
Check the security and privacy settings, update both security and Google update (alot of the time, people forget to update Google) then clear and wipe caches. Hope this helps
