Bespoke Washing Machine Drain Hose
(Topic created on: 05-30-2023 10:08 PM)
MP2605
Home Appliances
Hello everyone,
I wanted to ask for anyone’s input regarding situation as in the picture. Trying to get the drain hose of new Samsung washing machine but as seen in the photo it is falling short to reach the drainpipe.
Extension hose is an option but I am not experienced or know if there are potential downsides for adding aftermarket options - though surely cheaper. I have heard that it will void the warranty of unit.
There is a spigot under sink but would require another hole in the cabinet (there is already one for water outlet pipes). And how to get drain pipe 60 cms or above from ground if we attach to spigot?
Any other reasonable suggestions?
Thanks a lot.
3 Comments
Home Appliances
You could get a plumber out and swap drain and tap positions or extension
Home Appliances
If it is flex hoses to tap and drain you might be able to do it yourself.
Home Appliances
I think the extension hose is your best bet...
From their manuals, it says if the hose is too short to replace Screenshot_20230531_104850_OneDrive.jpg
