Washing balling up in my heat pump dryer
(Topic created on: 06-10-2022 03:36 PM)
boingy
Home Appliances
Hello fellow community members,
I have a question about washing balling up in my new Samsung Heat Pump Dryer - Model: DV90T8440SH.
The machine is running now with one queen size flat sheet, one queen size fitted sheet, and two pillow cases.
I've had to intervene in the process 4 times so far to un-ball the load.
My question is:
Does anyone have a tried and successful remedy to this issue? 🤔
Thanks in advance for your advice and assistance.
Kind regards,
boingy in Geelong, Australia 🇦🇺
3 Comments
SamsungLaura
Home Appliances
Hi @boingy, thanks for reaching out. Are you able to see if this issue occurs when only one sheet is in the dryer?
I am wondering if having multiple items twists them together.
Neetz1
Home Appliances
Please read my comment/reply to this issue
Neetz1
Home Appliances
This also happens to mine. I had one doona cover in the load. They're needs to be a cycle that alternates the direction of the drum to avoid this. Is there such a cycle? I would have thought bedding cycle should do this.
