Data connection problem
(Topic created on: 04-17-2024 11:59 AM)
MattPaul
Others
Hi everyone! im just asking, what simcard can i use here in phillipines? My phone is from australia.
13 REPLIES 13
GalaxyMel
Others
You can buy Globe, TM, Smart, Sun, TNT, or DITO simcards. They're available at the airport or at the malls.
MattPaul
Others
Im already using Globe and DITO simcards but the network always Emergency calls only. Im try a Smart sim but it's only the same Emergency calls only
Others
Is your device "carrier-locked" with an AUS mobile service provider? If yes, that could be the reason why. If not, try using SIM 2 instead of SIM 1.
MattPaul
Others
But my phone is no SIM 2 and i can only use my phone by using wifi connection
MattPaul
Others
My phone have signal but for data connection is no signal. If my phone is "carrier-locked" from AUS, why the GLOBE Simcard has signal but no Data connection? Pls. help me if you have an idea for this situation 🥺
Others
I thought it said Emergency calls only?
MattPaul
Others
Yes it's emergency calls only
Others
Is your phone e-sim capable? If so you may use e-sim from globe or smart.
MattPaul
Others
How to apply e-sim from globe? Here at phillipines?
