automation configuration question and help
(Topic created on: 09-05-2021 03:15 PM)
Smile5o1
Smartthings
Hello and I sure hope someone help me.
I’m just confused on trying to get a automation configured. I have been reading all sorts of information on how to set it up and it seems to not work the way I would like it. So, I came to you for some help hopefully.
Yet in the step-by-step choices I get a bit confused, and the setup is not what I’m looking for.
This is what I would like to have setup in automation.
So, if I’m away from my home with my cell phone with me in the car, and it gets dark outside, when I return to my driveway, I would like my front outside lights to come on and stay on for about 5 minutes till I’m in the house.
I have a smart light switch to the front door connected and works great.
Is this configuration possible with Smarthings to accomplish and so, can you please show me set by set on how to set this up? This is my first configuration setting up anything with Smarthings automations!
Thanks you so much for your generous help.
1 REPLY 1
Georgine
Smartthings
Hi, Welcome to the Samsung Members Community Canada. Please contact our dedicated Samsung smartthings support from the below link, they will help you with complete information.
https://www.samsung.com/ca/support/contact/#onlinesupport
