battery problem
(Topic created on: 04-28-2022 04:08 AM)
Delyoxx
Support
ILANG BESES  NA KO GUMASTOS NG PERA SA SAMSUNG GALAXY A01 KO FIRSTIME KOLANG MAG SAMSUNG TAS GANTO PALA EXPERIENCE HAHAHAHAHAHAHAHA HINDI KO MAGAMIT NG MAAYOS DAHIL HINDI NAGCHACHARGE MADALAS NAGBABAWAS PA SYA NG PERCENT KAHIT NAKA CHARGE NAMAN PLEASE HELP PO
5 REPLIES 5
butete
Support
from the description mukhang sa charger or cable
Matt52Playz
Support
Consider changing the charger (both the brick and the cable) but most of the time replacing the cable does the job and fixes the slow charging and if possible buy an original charger that comes with your device there is no problem buying a 3rd party brand mostly if its a reliable brand (watch for the wattage of the charger ofc). And after that its still slow charging its either the charger port or most likely the battery. Also try changing some software settings
buddyruiz
Support
How much do you spend
edward_6
Support
Muka common issue yan nag samsung galaxy A01 base sa research koScreenshot_20220429-114240_Chrome.jpg
lifeofzen
Support
galaxy a01 is one of a cheap samsung phone, so maybe that is why, maybe you should have just bought a better galaxy phone like a12 or something that has good specs
