Master Your Audio | Separate Sound
(Topic created on: 08-05-2025 12:37 AM)
Protonumus
Tips & Tricks
Located in the Sound and Vibration settings.
The 'Separate App Sound' feature on your Samsung device, lets you route media audio from selected apps (like Gemini, Spotify, or YouTube), to a different audio device, than your main output.
1. Simply turn it on, pick your apps, and ensure the audio device differs from your primary one.
2. Add more apps as needed, perfect for multitasking audio effortlessly!
Separate App Sound
Separate App Sound #2
SmartThings enables pairing two speakers together, as a workaround for creating speaker groups.
SmartThings | Media Output
Thank you.
4 REPLIES 4
Protonumus
Tips & Tricks
I'd love to use 'Gemini' as the wake word for Google Assistant, with compatibility for Echo speakers, or even a dual-assistant integration.
Currently, I use Alexa on my speakers and Gemini on my mobile phone.
Froglette
Tips & Tricks
I still use old faithful google. I don't like Gemini. And good informative post. 👍🏼
Protonumus
Tips & Tricks
Thank you. 😊
Tips & Tricks
Great post!
