New Battery Widget- Conveniently Monitor All Your Device Battery Levels
(Topic created on: 10-31-2023 03:41 PM)
SamsungClaudette
Tips & Tricks
You can now get a quick overview of the current battery percentages of your various galaxy devices through the Battery Widget. By adding this widget to your home screen, you can ensure that other devices like your Galaxy Watch5 and or Galaxy Buds2 Pro are sufficiently charged at all times.
Note: Update your devices to the latest software to use this feature.
Adding Battery Widget to Galaxy Phone/Tab home screen
Step 1. Press and hold onto a blank space on your Home screen
Step 2. Tap on Widgets.
Step 3.  Tap on Battery and select which type of widget you would like to use, then tap on Add.
Your new Battery widget should appear on your Home screen.
Step 4.  To customise the widget further, you can press and hold on the widget and tap Settings.
Step 5. Here, you'll be able to settings like 'Devices to show' or background colour.
2 REPLIES 2
Yasmik
Tips & Tricks
Nice feature.. everything under single hood😍
schnoodle
Tips & Tricks
It's massive and when I try to slim it down (from top/to bottom) it snaps back. I have a whopping 2 items in the list but the rectangle that takes up 1/3 of my S23+ screen. It's not obvious either that the 100% slider is the opacity for the background color (white/black)
